high idle on my rs turbo.why?
hello..
i bougth a escort/picup with a rs turbo motor yesterday.it has a very high idle usually around 2000 but it drops down to 1500 somtimes. any ideas why ?
thanks
kim
thanks
kim
Without knowing the spec of your car/pickup how can we give any sound advice?
is it standard, modded on mfi, has a DV, has indo management, just give a breif description of what you have as it could be a simple case of adjusting the idle on the throttle body.
thank you.
as i can se it is running 0,8 bar boost,no chip standard mfi.
nothing happens when i`m adjusting the idle on the throttle body.
remove the tps plug and the metering plug and then reset the idle it should go down.
once you find the correct idle replug the 2 back and it should be fine.
07-10-2015 12:56 PM
