braking problem, the story continues
Hejj alll,
Finally got my Zetec Turbo up and running so been driving around a bit.
Next problem is the braking issues it's stil having.
Problem when the zvh was in it was it was braking good at one moment and the other moment like the brake assist isn't working.
Now the thing is it feels like it has no brake assist all the time.
When i hit the brakes with the engine off and then start it the brake pedal goes down so brake assist should work.
Had the callipers off and pistons were moving fine.
Also replaced the brake assist and master cilinder.
who's got any ideas what could be the problem.
setup is 2wd 283 mm 4 pots @ the front and 253 mm disks with sierra calipers @ rear and wilwood bias.
Thanks
Thanks
I have exact same problem, i will next replace brake booster (servo)
Brakes properly bleeded and all brakes rebuilded.
(2wd cosw discs front with std rst calibers and rear drums
