mfi tps setting
Old Apr 11, 2009 | 09:54 AM
mark2's Avatar
mark2
Default mfi tps setting
hi all
right i bought myself a polished throttle body with the throttle postion sensor attached and when i place my one along side the tps are in different postions which i would expect and thinking i could just move new one into same postion for fitment but after reading haynes manual it says to get this set by fords
is this the case with the tps what would happen if i just set the new one the same as old one or am i asking for trouble , tobe honest all the years around rst stripping ,repairing them i have never had to change one
if it was not set right what are the signs of trouble
mark2
Old Apr 11, 2009 | 10:07 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
all u gotta do is set it to soon as u touch the throttle, it clicks!
Old Apr 11, 2009 | 10:26 AM
dangerousbrian's Avatar
dangerousbrian
mine needs adjsting aswell...can this clicking noise be heard when the engine is off? bit hard to hear anything on mine when the engine is running
Old Apr 11, 2009 | 10:40 AM
orion_crazy_carl
orion=mini saff
yeah,its a micro switch click
Old Apr 11, 2009 | 11:34 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Also make sure it clicks at WOT otherwise you'll be lean!
Old Apr 11, 2009 | 11:39 AM
mark2's Avatar
mark2
hi
so if i do it like this then fit new throttle body switch engine on not running with the screws holding tps loose ,operate throttle whilst looking at butterfly for slight opening then move tps untill it clicks would this do the trick
also do you know what to look out for if its not right setting/ further adjustment needed
many thanks
mark
Old Apr 11, 2009 | 11:44 AM
mark2's Avatar
mark2
hi
(clicks at WOT) mmm puzzled is it with open throttle ( full throttle )
cheers
mark
Old Apr 11, 2009 | 11:58 AM
Karlos G's Avatar
Karlos G
Balls Deep!
yeah Wide Open Throttle
Old Apr 11, 2009 | 12:00 PM
mark2's Avatar
mark2
cheers peeps been a great help once again
many thanks
mark
Old Apr 13, 2009 | 04:33 PM
tiff_lee's Avatar
tiff_lee
Mine must be buggered as it only clicks initially when opening the throttle and not at WOT.
I removed it and used a flat headed screwdriver in the slot and still only one click.
This would explain my poor throttle response and lack of power above 4K revs hence the reason I been driving it around like a granny on the way to ASDA.
Old Apr 14, 2009 | 02:16 PM
mark2's Avatar
mark2
hi all
i only have a click as the throttle opens not WOT i have tried a couple of tps and they all do not click at WOT can someone clarify this , i do have a brand new one somewhere will try that in the week
mark2
Old Apr 14, 2009 | 02:29 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Mine clicks just as you touch the throttle and this was etup by Jano at oddkidds.
Old Apr 14, 2009 | 02:35 PM
mark2's Avatar
mark2
same here mine was setup not long ago and only clicks as you touch throttle
out of the three i tried one did drop the revs by 100 rpm and was a git to start but that clicked not WOT though like all the others
put old one back in for now see what replies i see here
mark2
Old Apr 14, 2009 | 09:29 PM
project rs's Avatar
project rs
obviously karlos g giving out odd information as the 3 i've got here all only click once maybe he could up load a video for us of his clicking twice and the voltage along with it as as far as i'm aware they click so ecu knows when to run fuel shut of when slowing down as those with afr's in car will have noticed the guage read in the 20's when off throttle slowing down and it reads full throttle via voltage from tps not a click
Old Apr 14, 2009 | 10:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmmmm maybe i am wrong?!
I have not actually checked my own to be 100% but i'm sure i read one of Stu's articles on the KE system and he said the ECU registers 3 positions, Shut, WOT, and in between (no microswitches active), it's definitely not a variable potentiometer though.
But it looks like the odds are against me!
Sorry!
Old Apr 15, 2009 | 06:52 AM
danskfocus's Avatar
danskfocus
There is a full load (WOT) switch inside, but it doesnt click, its a bladeswitch. I have uploaded a picture of it to my album.
Old Apr 15, 2009 | 08:54 AM
addiction's Avatar
addiction
The way i was told to do it is to push the tps onto the throttle body (will only go on one way) then turn the TPS clockwise towards the bulkhead till you here it click then tighten the screws. Now when you move the throttle arm you should hear the click again.
Old Apr 15, 2009 | 02:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thanks for that you are quite right!
But as you say it's a reed switch not a microswitch so will not click.
Old Apr 15, 2009 | 06:46 PM
mark2's Avatar
mark2
so do we have the setting sorted now gents i have set mine and no problems
marks
steve.rst
Mar 15, 2016 08:01 AM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
ajamesc
Sep 27, 2015 02:25 PM
lime
Sep 25, 2015 06:56 PM
