highest ratio 'BC' mk3/4/5 escort gearbox ?
anyone know what model of mk3/4 or even 5 escort had the highest ratio gearbox ?
or are they all the same ?
my TDI estate has plenty of torque but not enough revs so is revving quite high at motorway speeds
Time to play The Game HHH
The actual gear ratios are the same for the Series 1 and Series 2 gearboxes, the only gear difference is the final drive ratio.
The Series 1 RST had a 4.0:1 final drive and the Series 2 had a 3.8:1 final drive ratio, this is what makes the Series 1 feel better on acceleration and gives the Series 2 better top end speed.
cheers , any idea what 5th gear ratio is on the diesel mk5 box ?
or any idea which has the highest 5th out of all the boxes not just the RS's ?
To be honest no, but if you give a search in the forums you will surely get the answer. I know that info cause I recently spoke to one of Bernie's guys for my box
