s1-s2 turbo part numbers
mite want to make this a sticky i made this up some time ago hope it helps
Escort rs turbo part numbers
lower gasket kit 5028483 s1
Lower gasket kit 5028484 s2
Upper gasket kit 1023225 s1-s2
Timing belt 6711046
Sprocket 6087221
Camshaft 6186554
Camshaft seal 1669254
Oil filler cap 1610085
Rocker cover gasket 1651775
Head bolts 6088344
Head bolt washers 6585829
Tappets 6129778
Head gasket 1658584
Camshaft cap 6470101
Temp sender 6146864
Exhaust gasket 1023231
Exhaust washer 1465430
Exhaust nut 6134209
Exhaust stud 6144958
Elbow drain 1640090
Down pipe stud 6143971
nut for down pipe 6503553
gasket for turbo 1026211
oil feed pipe 1647776
Starter heat shield 1644016
Throttle switch 1626474
Cold start valve 6165239
Cold start gasket 6150597
Water temp sensor 1633020
Thermal time sensor 6052774 85-88
Thermal time sensor 1651725 88-91
Inlet outer gasket 1013229
Inlet inner gasket 1023228 s1
Inlet inner gasket 6851355 s2
Inlet nuts 6076340
Throttle gasket 6053888
Oil pump 6085097 s1
Oil pump 6169335 S2
Oil pump gasket 6169337
Oil filter efi 500 1070523
Oil pressure switch 1066811
Sump gasket 6166108
Sump plug 1454117
Sump plug washer 1454118
Water pump 1126041
Water pump gasket 6186825
Thermostat 1635905
Thermostat gasket 1610063
Thermostat rubber 6073070
Thermostat clip 0242120
Thermostat switch 7001611
Thermostat washer 6005731
Fuel filter 5020405
Banjo bolt up 054980
Banjo bolt lower 6054979
Washer upper 1503882
Washer lower 6054981
Crank case filter 6141135
Crank case hose 6187489
Crank case hose 1643865
Rubber c/over pipe 1659082
Screw c/over pipe 1494813
Blot c/over pipe 1547304
Air temp sensor 6740335
Alternator belt 6738365
Starter motor 1.4 1416217
Heatsheld bosch 1654781
Dissy cap 0710254
Rotor arm 6134771
Dissy assy 6182576
Ignition leads set 1202510
Spark plugs 071s 1120834
Clips for leads 1641009
Clips for leads 6647780
Clutch 220m 5026003
Hood 1661822
Water header tank 1651060 87-89
Water header tank 6201893 89-91
Header tank cap 7267969
Lower rad hose 6201894
Upper rad hose 6198202
Fuel pump 1613157
Fuel pump hose 6166980
Fuel bracket lower 6168055
Fuel bracket mid 1648035
Fuel bracket up 6168054
Fuel cap 6168972
Fuel cap lock 6201022
Fuel pump relay 6145938
Tie rod end 6168980
Lower arm right 1058191
Lower arm left 1058202
Acc cable 1643960
Break light switch 6088639
Break discs 1102560
Break pads 5023998
Brake shoes 1638304
Break pipe servo 643753
Engine mount 6178900
Bonnet vent left 1666275
Bonnet vent right 1666274
Bonnet hood clip 1629999
Bonnet grommet 6068981
Bonnet cable 1643604
Clips for washer hose 1654234
Rear light gasket 6138965
Reversing lamp switch 6031219 86-89
Reversing lamp switch 6871978 89-91
Timing belt 6711046
Sprocket 6087221
Camshaft 6186554
Head bolts 6088344
Tappets 6129778
Head gasket 1658584
Temp sender 6146864
Exhaust nut 6134209
Elbow drain 1640090
Inlet nuts 6076340
Oil pump 6085097 s1
Oil pump 6169335 S2
Sump gasket 6166108
Sump plug 1454117
Water pump 1126041
Thermostat 1635905
Fuel filter 5020405
Dissy cap 0710254
Rotor arm 6134771
Dissy assy 6182576
Clutch 220m 5026003
Hood 1661822
Fuel pump 1613157
Fuel cap 6168972
Tie rod end 6168980
Acc cable 1643960
Break discs 1102560
Break pads 5023998
Brake shoes 1638304
paceo
03-02-2016 10:31 AM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
