central locking
Old Feb 12, 2009 | 05:57 PM
ian_evs2003's Avatar
ian_evs2003
Default central locking
ive got a toad alarm centrall locking system,, and when u close it it works and re opens it self, could this be due to a solenoid gone and somthing else?
Old Feb 12, 2009 | 06:15 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
its one of the door motors mate one will be clicking all the time mate
Old Feb 12, 2009 | 06:52 PM
coswurv's Avatar
coswurv
first of all make sure your locking mechanism is not seizing up and is working ok, then i would suggest removing your speaker covers in the front footwells and checking the plug that connects to the central locking motor (think its the white/clear plug) these pretty much always corrode and play up, i just reomved mine a soldered the wires back together eliminating the plug, worked a treat and has been fine for over 3 years, may help you out.
Old Feb 12, 2009 | 09:03 PM
makaveli96's Avatar
makaveli96
Could be broken wires getting pulled through the door.
Old Feb 12, 2009 | 09:12 PM
Steve_RS's Avatar
Steve_RS
What he said - check the plug behind the speaker - drivers side. Mine was shorting out on the chassis and causing the doors to unlock then lock straight away.
The other one is the electronic boot lock. Try unplugging it and see if it cures the problem.
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
