next mod for more bhp
i have a s2 rs turbo...... gotech engine managment, radtec front mounted intercooler, t34 turbo full scorpion dtainless steel exhaust running at 182bhp .......
what does you tunner say when you ask him this??
but why o why have you got an t34 with only 182bhp that must take 2 weeks to come on boost and be so undriverable
yam yammer
Fair enough mate. It all depends on the rest of the spec of the engine but you should have a lot more power IMO. How come you are going to change the turbo? Is it really laggy? If I were you mate I would get in touch with a tuner who can set up your car and ask them the best course of action. Problem is not many companies set gotech up I don't think.
to be honest, the car dont feel that impressive for 182bhp..... and im nt sure if it is anyfin to do with the turbo or if the car isnt set up tidy but i hav a receipt for a rolling road set up in jamsport 5 months ago
didnt think they would have set it up on the t34 running that power must be on boost so so late.get on the phone to them mate,might have records of the car under its reg and they could tell you what they hink or thought of it when they did it.or just go see them.good blokes up there
im a 3 hour drive away from jamsport you see...... so im in a bit of a confussin situation u see....... what the best thing i can do is it keep the t34 or get a new t3 nd set it up or set it up onb the t34????????
and will they turn the boost up in the setup in jamsport.....
i have a switch inside the car on the dash that changes it frm low to high boost but seem to hav mor lag on the high boost?????
yam yammer
Yes they will turn the boost up during the setup but they will charge an extra 30mins labour even though it didn't take any longer than the 2 hours they said it would take to setup
Balls Deep!
If your bottom end (Crank, Rods, Pistons) are standard then ditch the lag monster (T34) and get your stage 2 T3 and aim for the 210 - 220 bhp mark at Jamsport.
If your bottom end can take more (steel rods, forged pistons etc..) and your head has been worked (ported, polished, big valves etc..)then with the T34 you could see around the 250bhp mark!
so changin to t3 and getin it set up in jamsport i will see a fuk of a difernce in the car then?????
what psi should i set it at???
and what would the switch in the dash b changin boost and how ???
i think the best thing to do is find out exactly what engine mods you have,carnt belive you dont have a cam with that spec,still at least you have an uprated management thats a few quid saved,if your gonna strengthen the engine and get a big valve head,then turn the boost up,or spend your wedge on getting the power down on the road,atb diff,uprated steering arms,polybush it,at the end ot the day it depends on how much folding stuff you have........
ah ok what psi should i tell jam sport to set it at?????
so say if i set the psi to 14..... wen i flick the switch itl giv a lil extra boost and wen i flik it back it will go bac to the 14psi it set at????
im only askin so much as its my first time with an rs and would like everyfin done properly
Balls Deep!
Basically..... yes!
Best way mate, it will cost you BIG money if you get things wrong
ok cool ah im so glad theres some people that no nearly everyfing about these cars
i fink ill ditch the "lag monster" get myself a stage 2 t3 turbo and go pay jamsport a visit......
do u really fink i could hit the 200+bhp wen i get it set up that day in jamsport?
ive just been out for a spin in my m8s rs turbo which is member ian_evs2003 hes got an rs runnnin 170 bhp using a t3 turbo
and that wud leave my rs standin the lag diference is unbeleivable and mine is so underpowered compared to it new turbo defo
i get a lot of backfires frm the car and it pops a lot and the turbo flutters....... also quite lumpy on idle but bin told thats because of the gotech
ok people hers what im guna do im guna save up some spare cash.... get myself a garrett t3 stage 2 hybrid turbo and give jamsport a visit and get them to set up my car with the stge 2 t3 fitted......
that a good idea people and hopefully irt will be ruinnnin a bit mor dan 182bhp and with the plus side of no lag
thanks lads
thanks lads
SMILER258
28-09-2015 09:04 AM
