roof headlining removal
use a hair dryer to heat up the edges before you try and remove it as the lining becomes brittle over time and tends to break/split when you try to remove it
i heated mines at the bootlid/tailgate part, picked that away, managed to pull it from under most of the trim, worked the rod out, pulled the rubbers out a bit and took the headlining out an inch at a time, took the b-biller trim off, took the door seals off at the top, worked it out from the a-piller and sunroof part then took the sun visors and sunroof handle off and worked it from under the windscreen rubber.
haven't put it back on yet
because it's hard, just time consuming. You'll be fine if you keep your composure, stay calm and take your time. Lose your rag and you'd better be ready to buy a new headlining.
i can't comment on puting it back in, if its just the reversal that'll be a hard-arsed job
CAR FOR SALE!!!
Mate ive done mine. any wolly can do it. I removed all components from the roof, peeled off door seals and hairdryered it off. because it was so rotten n mucky i have replaced it with black vinyl. i completely re-sponged the roof after sanding down and respraying. fitted the lining back up using the old rod sowed into the vinyl and some vinyl adhesive. I used the old lining as a template but overcut about an inch. after fitting it back up cut off excess then put rubbers and handles etc back on. looks mint. I had no problems i done it all done it all on my own. (part from me mum sowing the rod in and recovering the sun visors )
i bought another roof lining to put back in as the one in now is knackered,im off up to my mates garage where the car is at the moment on monday to take it out,and see whatthe roof looks like.
CAR FOR SALE!!!
you will see what i mean its cushty to do. I will take a pic of mine 2mora. But passionford mite not let me upload it coz my files are 2 big as i have 8mpx camera phn. ill try tho lol
ive taken all the plastics off,the one place im struggling with is the sunroof area,as in the plastic where the handle sits in,and also the rubber around the sunroof.
