i hate electrics!....
Old Jan 26, 2009 | 10:10 PM
RS_JASE's Avatar
RS_JASE
Default i hate electrics!....
bloody electrics! lol
when i turn the ignition on only the row of orange lights illuminate in the clocks.
they flash for a bit, then go out.
theres no charge light or oil pressure light
any ideas why?....
also the temp gauge dont work, but the fuel gauge does. wierd! lol
Old Jan 27, 2009 | 05:38 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
dash light module/ecu?
Old Jan 27, 2009 | 08:49 PM
RS_JASE's Avatar
RS_JASE
oh christ!.... lol
how do i check to see which it could be?
Old Jan 27, 2009 | 09:52 PM
sm's Avatar
sm
oil pressure light- check the plug is connected on the oil pressure switch on the back of the engine
temp gauge- check the temp sender unit wire is connected on the front right hand side of the head if so try a new sender there only a few quid
battery light - could just be a blown bulb other than that try and check the wiring for any breakages
i take it its a mk3 escort, if so the dash light module is behind the dash in the centre, if u remove the dash'es centre speaker/centre heater vents then you should see it, its a yellow ecu like box, u can pick them up on ebay quite cheap now and again
Old Jan 28, 2009 | 09:44 PM
RS_JASE's Avatar
RS_JASE
thanks for that, i will check them out
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
