hi all, ive got 1.8 zvh in my s2 and want to convert to ofab management, question is, can i use a fiesta rs turbo flywheel with the bolt holes oversized to fit the crank, also has the zetec block got the cps hole in the correct place so that i can just put the sensor in without having to machine the block? any help would be great. cheers
you can use the FRST flywheel with the holes drilled. i used the zetec gearbox (stronger mainshaft bearing), flywheel and crank sensor with my FRST padle cluch
