abs removal
remove all abs, modulators, belts and pipes and throw it away. fit a brake fluid reservoir from another model or seal off the old pipes. run two new brake lines from master cylinder to t-pieces on each inner wing. job done.
![](https://passionford.com/forum/images/smilies/roi.gif)
can it be done with engine and box in car? or maybe shafts have to come out?
hope this helps guys... get rid of all the junk and add the red coloured pipework ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
I never changed the res... just used fluid hose and looped it back... so it just recirculates.
![](http://i94.photobucket.com/albums/l100/gumble_01/absguide.jpg)
![](http://i94.photobucket.com/albums/l100/gumble_01/absedited.jpg)
Kind regards,
GUM
Kind regards,
GUM
i did mine when engine and box were out but if doing it with engine and box in then i would imagine you would have to pop the shafts out of the box yes.
