bailey breather on efi engine
ive converted my rst to efi and i had a bailey breather kit fitted and i want to keep it on the efi but what do i do with the small breather that runs off the efi inlet? do you blank it off or just let it vent?? anybody else done this any pics or help thanks
really it should be connected to the breather using a one way valve like the one you should have in line from your inlet to the map sensor
buts it fine just to block it off or use it elsewhere as a feed to a boost gauge etc and the car won't run right if you just vent it.
JoeyBoyden
18-08-2015 10:52 PM
