Engine questions
I think i can...
Engine questions
Hi guys,
I wanted to know, what are the differences between a std. Ford Escort 1600 MK 3-4(non-turbo), to a Escort RST MK 3-4.
What i wanted to know is can i buy an old block from a std. escort 1600 and put on my RST.... to use my turbo, my cylinder head etc'....
Is the block the same ? pistons the same ? and botton end ?
Thanks for any help mates
orion=mini saff
u can use a normal bottom end,but u will need to tap the sump for the oil return as the turbo block has one built in!so yes u can,but its not easy as just swapping it over
I think i can...
o.k so if i take a normal block and sump the oil return, can i use the std. pistons and botton end ? will it hold ?
I think i can...
so if i get the std. block i need to buy and RST bottun end and pistons,
what about the head ? can i use a normal one or again must be an RST one ?
Hi guys,
Mite be easier to rebuild your existing rs turbo engine
