battery help.
Old Nov 28, 2008 | 11:16 AM
ricky_2006's Avatar
ricky_2006
Default battery help.
need a new really good battery.
needs it to be over 560A
and idealey it needs to be square terminal.
any suggestions please. need to fit in a s2 escort
Old Nov 28, 2008 | 11:56 AM
raycov's Avatar
raycov
bosch silver top about 50 quid with a 4 year garantee brilliant
Old Nov 28, 2008 | 12:14 PM
B16CVH's Avatar
B16CVH
I always get a good one from a tat yard for a mk5 diesel, they are only a tenner, have plenty of cranking power, never had a problem!
Old Nov 28, 2008 | 01:50 PM
ian r's Avatar
ian r
i put a 097 that i have on mine biggest 1 that would fit in the battery tray
Old Nov 28, 2008 | 07:24 PM
makaveli96's Avatar
makaveli96
Go for a Heavy Duty 620amp Calcium Battery from Halfords they are good if your running a heavy sound system I think I paid £50 for it and it fit's ok apart from you will have to undo the two bolts and slide the ignition coil a bit higher then tighted the two bolts again as the battery is a bit longer.
Old Nov 28, 2008 | 07:26 PM
ricky_2006's Avatar
ricky_2006
i ended of getting a 095 from euro car parts which i think is 640A and just fits in the tray
Old Nov 28, 2008 | 07:29 PM
makaveli96's Avatar
makaveli96
You got a result there mate how much did you pay for it and was it brand new?
Old Nov 28, 2008 | 07:31 PM
ricky_2006's Avatar
ricky_2006
i knew a geezer who worked there. yeh was brand new and got it for £51.64. i thought that was well cheap mate
Old Nov 28, 2008 | 10:24 PM
ian r's Avatar
ian r
glad you got it sorted
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
TC-ST3
Sep 26, 2015 04:47 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
