engine oil for a S1 escort turbo
Received 1,044 Likes
hi people whats the best engine oil for a S1 escort turbo. Since my mate has done a oil change on his car it smokes every now and then. It was ok before he changed the engine oil.
It really depends on your application.
Standard bottom end generally 10w40 or if you have a modified bottom end then it is definatley 15w50.
All oils should be fully or semi synthetic.
I would personally reccomend Mobil 1 15w50, fully synthetic.
Smoking could be due to a different viscosity being used which may now be passing oil seal and getting into the combustion chamber. Check for leaks.
Which oil was used?
Which oil was used?
i use silkolene pro s 5w-40 as recommended by oilman on here, message him on www.opieoils.co.uk with ur engine spec etc and he will tell u whats the best oil for your application
big_Rad
15-09-2017 09:36 AM
