cossie management on rst
Old 18-07-2008 | 07:10 PM
adduk's Avatar
adduk
Default cossie management on rst
hi i know this question will probably of been asked loads of times before so if it has if somebody could point me in the direction of a link il have a look at them,but what it is im putting cossie management on me series 2 zvh and i have a 4x4 loom already and l8 ecu,its just what else im going to need. first thing is are all the sensors the same for 2wd and 4wd,also what sensors do i need to get and what do i need to do in regards to the throttle body and dizzy.Any help and advice would be great,cheers adam
Old 19-07-2008 | 09:57 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
I run cossie management with a trigger wheel setup for timing, as I do not use a dizzy, I use coilpack. For the throttle body I run a cosworth throttle body on a modified FRST manifold with modified valve ( I run anti-lag)
Old 19-07-2008 | 01:05 PM
adduk's Avatar
adduk
hi cheers for the reply.does the throttle body have to be 4x4 or 2wd or doesnt it make any difference. and same for the sensors when i find out which ones i need do they need to match the 4wd loom or not.cheers
A.t.p
23-10-2015 07:54 PM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
griffo69
04-10-2015 11:58 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: cossie management on rst
