anti lag and roll cage
hello i have been looking but seemed to have no look. i was wondering if anbody can link me to a site that sells anti lag kits for a s2 rsturbo and also wondering if there are any roll cages that can be fit but still have the use of the back seats. i have seen a few people with these type of cages but i cant seem to find anywhere that sells them.
thanks.
thanks.
anti-lag requires a ECU capable of doing this along with other associated a parts such as a modified throttle body in some cases, if you are going to run aggressive anti-lag I would suggest getting a maram shafted turbo as the life expectancy of your turbo without this will be reduced greatly.
If you do not have after market management capable of doing this, you should be able to get this whole lot done by most popular tuners depending upon the choice of management.. expect to pay £1k upwards for management with Anti-lag fitted
The roll cage you can get from Safety Devices, http://www.safetydevices.com/
unless of course you want one of those over sized bling 'show' cages.. in which case you would want fusion found at http://www.fusionfabrication.fsnet.co.uk/rollcage.htm
The cost of a decent cage would depend upon if you wanted bolt in cage or weld in cage, door bars, etc... call safety devices and talk to the people who know.
Alternatively you could get someone who specializes in fabrication to make you one to suit your needs
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
