inlet mfi
Old 22-04-2008 | 11:05 PM
boothy's Avatar
boothy
Unhappy inlet mfi
hello ,basicly took the inlet off to spray it put it all back together but there are 2 hard plastic pipes that cum off it 1 of them on the side other on the back just wonderd wheare they went please could sum 1 put a picture up of the inlet cheers rob
Old 22-04-2008 | 11:43 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
One off the side goes to your brake servo iirc
Old 23-04-2008 | 10:04 AM
boothy's Avatar
boothy
no mate sorted that 1,if you look a the inlet from the front of the car its on the left and the other is on the back hard plastic pipes please could you get piccys up
Old 23-04-2008 | 10:14 AM
Dragsteer's Avatar
Dragsteer
maybe you mean on pipe for auxilary device? one pipe is under mainfold (under throttle butterfly) second is on back on inlet mainfold.
Old 23-04-2008 | 05:47 PM
Daveysaff's Avatar
Daveysaff
I'm not the person to ask, i'm only converting mine to weber because I cant get my head around KE
Old 23-04-2008 | 07:27 PM
bad boy rs's Avatar
bad boy rs
As above mate
I think the hard plastic one on the rear of the inlet goes to the auxlilary air device
When mine was mfi i changed the hard plasticc pipes for normal rubber hose from local motor shop, they prone for leaking
Old 23-04-2008 | 11:03 PM
boothy's Avatar
boothy
thanks all ,sorted it just forgot were it went,ill know for next time,i will change thempipes to rubber
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
Johnny Knoxville
30-09-2015 07:21 AM
Quick Reply: inlet mfi
