trigger wheel
Old Feb 4, 2008 | 04:15 PM
Butchi's Avatar
Butchi
Default trigger wheel
Hello.
Im concidering to change to megasquiert. I have a erst -87 so I have to change a lot of things.
My question is, if Im not interested of lifting the enginge and drill a hole to the senser thats indicates on the trigger wheel at the EFI cars, is it possible to work something out at the cam wheel ore the crank shaft wheel (sorry, I dont know the english word for those things).
Can you fit a sensor there and put a trigger wheel on those wheels?
BR BUTCHI
Old Feb 4, 2008 | 11:57 PM
NUTS RuS's Avatar
NUTS RuS
Well it is done on the cam on YB engines so I guess so
Old Feb 5, 2008 | 01:01 AM
Mixja's Avatar
Mixja
420
not sure if megasquirt runs on the 4 lugs like the cossie or th 36-1 like the efi/fiesta but im sure you could do both on both pulleys...
Old Feb 5, 2008 | 06:08 AM
Butchi's Avatar
Butchi
The megasquiert works with a 36-1 trigger wheel.
From the pictures above, it will work if I place the trigger wheel on to the crank shaft pulleys.
Thanks mates!
Old Feb 5, 2008 | 08:47 AM
JesseT's Avatar
JesseT
The megasquirt has a universal wheel decoder so you can use practically any number of teeth. And all this only if you want to go wasted spark of course. Otherwise you can just use the original distributor if you wish.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
