missing on start up
Old Jan 27, 2008 | 10:11 AM
B1G_RST's Avatar
B1G_RST
Default missing on start up
ok replaced the headgasket on th escort,used to start 1st turn everytime,now she take 3 or 4 turns and misses like hell on start up,once warn she runs great but misses on start up quite badly,cant be ht leads, coil, plgs ect can it as it runs fine once warm
Old Jan 27, 2008 | 05:50 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you checked all the hoses for air leaks??
Old Jan 27, 2008 | 06:06 PM
B1G_RST's Avatar
B1G_RST
sure have mate,its going for a set up as soon as i find a trasporter so wil find out then
Old Jan 28, 2008 | 06:56 PM
Fiecos Dan's Avatar
Fiecos Dan
So all you have done is the headgasket?
what spec and mod's?
try disconnecting the cold start, as all they do is flood on cold start.
Old Jan 28, 2008 | 08:44 PM
B1G_RST's Avatar
B1G_RST
tryed removing the cold start valve today,never did worked tho,its only wen revving above 3k,once warm ect it runs fine,
Old Jan 28, 2008 | 09:44 PM
turbocat's Avatar
turbocat
I had the same problem I just fitted 4 brand new injectors now no probs I had 2 that where leaking fuel into the bors overnight so it had to burn the fuel before it run ok. I went over everything before I found it was this.
Old Jan 28, 2008 | 10:19 PM
B1G_RST's Avatar
B1G_RST
can you remember how much the injectors wer big man ?
Old Jan 29, 2008 | 09:28 PM
turbocat's Avatar
turbocat
Yes mate only did this last week cost me Ł90.78 I had to give in my old ones or they wanted an extra Ł60
Old Jan 29, 2008 | 09:52 PM
Chris69's Avatar
Chris69
did you have the head skimmed? or checked for flatness?
have you done a compression test?
Old Jan 29, 2008 | 10:45 PM
Billy_RS's Avatar
Billy_RS
Just do the basic checks.
Leads, Plugs, dizzy, coil, metering unit, ijectors, lines, timing etc....
If its getting setup, it will probably be found anyway.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
Marino
Sep 12, 2015 11:10 AM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
