std cam
Old Dec 28, 2007 | 07:00 PM
juffer's Avatar
juffer
Default std cam
proberbly going to get a lot of stick for this but has anybody tried a std cam with a adjustable pully and had any good results. also to get over 180bhp have you got to chang your cam?
answers much appreciated
Old Dec 28, 2007 | 07:25 PM
turbo.jon's Avatar
turbo.jon
Std cam will be fine with few other mods like stainless exhaust,air filter,chiped ecu running about a bar of boost should see you about that a good intercooler like grs would help too...
Old Dec 28, 2007 | 09:52 PM
swerv's Avatar
swerv
why are you going to get stick?
i have a standard cam with an adjustable pulley, all dialled in correctly, runs lovely and smooth, around the 200hp mark.
to get more power i would need to do a lot of work and its been reliable at this so its staying at this
in all fairness you dont need to get an adjustable pulley with a standard cam, why are you considering it?
Old Dec 28, 2007 | 10:01 PM
juffer's Avatar
juffer
cheers for the posts. i want a good 200bhp. i have heared that you dont need a kent or piper cam to get good resaults. I was just thinking of getting a adjustable pully to get all the timing spot on and it may give me a few cheap bhp and run correctly.i ran my engine on the rollers and got 153bhp with standard cooler which turns out was shit. since then i have put a new cooler on my spec-
std block and head
t3 turbo
-31
superchips ecu
k&n
magnex exhaust
twin pass fmic
Old Dec 29, 2007 | 02:21 AM
Fiecos Dan's Avatar
Fiecos Dan
A new std cam timed in correctly will do wonders if the old cam is worn.
Old Dec 29, 2007 | 08:42 AM
swerv's Avatar
swerv
i would go and get yourself a proper chip with proper ignition on it like turbosystems, then get the pulley on and get the cam properly dialled in, rocker needs to come off for this
you should like the results i did
i would steer well clear of the efforts from kent and piper btw
20/20 vision
Sep 29, 2015 09:25 PM
