engine differences?
Old Dec 9, 2007 | 09:40 AM
petermintrst's Avatar
petermintrst
Default engine differences?
What are the differences internally to a n/a cvh from an xr3i and an rs turbo engine.
Reason I ask is that I have an xr3i engine that I will be rebuilding and I wouldnt mind rebuilding it into an rs turbo engine. As the block and cylinder head are the same physical size surely it is possible....is it?
thanks
peter
Old Dec 9, 2007 | 10:46 AM
Chris69's Avatar
Chris69
i'm pretty sure the block is the same but obvio the pistons are lower compression mahle items.
i've heard the valves on the rst head are slightly differnt (surface coating or somthing but tbh i don't think thats a big issue.
not sure if the rods are differnt etc
Old Dec 9, 2007 | 10:51 AM
addiction's Avatar
addiction
you'd also need to drill a hole into the block for the turbo oil return pipe
Old Dec 9, 2007 | 12:47 PM
jonesymk2's Avatar
jonesymk2
the erst crank is slightly different,the erst uses different big end bearings i think aswell,pistons are different for lower compression,xr3i block has to be drilled to take turbo oil return,there is something different on the heads but cant remember what it is,as far as i know thats the differences
Old Dec 9, 2007 | 06:33 PM
petermintrst
going on the comments (thanks everyone) it might be less hastle just buying turbo engine to rebuild
Old Dec 10, 2007 | 12:03 AM
Billy_RS's Avatar
Billy_RS
I'd rather use a RS turbo engine. You can get them on eBay for decent money
Old Dec 10, 2007 | 11:09 AM
jonesymk2's Avatar
jonesymk2
yeh that would probably be your best bet mate
Old Dec 10, 2007 | 04:31 PM
orion turbo's Avatar
orion turbo
rs turbo exhaust valves are sodium filled (n/a cvh's are nimonic)
8.3;1 comp ration (n/a 9.5;1)
secondary oil rings are tapered
beefier gudgeon pins
main bearings are uprated from xr3i spec
retarded cam timing by the fitment of a 1.3 cvh cam sprocket
sump had oil return
xr3i and rs turbo k-jet and ke-jet are the same the E in the ke only means electronic control of the cold start valve and period
Old Dec 10, 2007 | 07:59 PM
petermintrst
sump had oil return
you sound like you know nothing about engine....
cheers for that
Old Dec 11, 2007 | 12:47 AM
orion turbo
is that sarcasm
every single car except 2 has been cvh
Old Dec 11, 2007 | 11:31 AM
petermintrst
sacasm.....yes
how many cvhs you had?
And for my next question....if I was to buy an rs turbo engine and replace all shells, rings bearing, re grind crank etc etc with standard parts...how much would it cost roughly (for the parts)
Old Dec 11, 2007 | 01:24 PM
orion turbo
cvh's have to guess at something over 20
the shells and rings ect. are not that expensive and the crank work wont cost a forture butit depends who builds the engine?
Old Dec 11, 2007 | 02:00 PM
petermintrst
an cheap amateur would fit it together but the regrinding/honing would be done by a proffessional.....then when it goes bang the minute i turn the key
Old Dec 11, 2007 | 04:49 PM
MarkN's Avatar
MarkN
I had my Mk3's original engine rebuilt as a turbo block back in May. I got the CPS hole drilled at the same time so that I could run FRST management.
Be warned though - the NA and Turbo block castings are different. The turbo block has extra metal on the inside where the turbo oil drain hole is to "point" the oil straight down into the sump. When you get a NA block drilled the drain stub just pokes through the wall and the oil runs down the inside of the block.
I converted mine because I wanted to keep the original engine number. I also got the bargain of the century with a new set of pistons, rings and shells for Ł20 of ebay. Made it a no brainer really rather than buying some unknown RS turbo block that could turn out to be a pile of crap...
Old Dec 15, 2007 | 11:50 AM
whitneyd's Avatar
whitneyd
Is ther any differences in the Fiesta turbo blocks and the Escort turbo blocks??
Old Dec 15, 2007 | 03:12 PM
MarkN's Avatar
MarkN
I don't think so apart from the CPS hole that most Escorts don't have.
The fiesta block also has a threaded oil drain, but this is not technically part of the block and can be extracted and replaced by a t3 version...
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Gadget
Aug 26, 2015 01:02 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
taylora1409
Aug 12, 2015 12:06 PM
