bearings and piston rings
hi ppl
im going to be changing piston rings and main bearings and big end bearings but iv noticed that there are different sizes, will the sizes for the piston rings be on the piston and will the size for bearings be on the crank.
cheers
lukeyboy
cheers
lukeyboy
The pistons should have
Std, or +0.25, or +0.50 or + 1mm
the shells will have.
Std, or -0.25 or -0.50mm.
if not your have to measure the bore's, and crank.
Also while your doing it, change the oil pump.
deathrider666
28-09-2015 06:12 PM
