efi conversion
Old Oct 13, 2007 | 09:07 PM
ginner s2's Avatar
ginner s2
Default efi conversion
hi has anyone used a adapter plate on the mfi head to fit the efi manifold .are there any probs wiv them or should i just get an efi head
Old Oct 13, 2007 | 09:36 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
There are no problems with the EFi adaptorplate i supply as for others i cant comment
Old Oct 13, 2007 | 11:32 PM
Chris69's Avatar
Chris69
imo u should bolt on a nice EFI head unless the mfi head u've got has some serious money spent on it, if it does then keep it
Old Oct 14, 2007 | 12:20 PM
RST Ski's Avatar
RST Ski
i used a adapter plate from ferriday, no probs with it working except that the studs only had afew threads left on them as the adapter plate was quite thick
Old Oct 14, 2007 | 03:08 PM
bad boy rs's Avatar
bad boy rs
Default efi
I bought one from oddkid and it works a treat
Old Oct 15, 2007 | 05:42 PM
steven botes's Avatar
steven botes
not required!!!
the std carb/mfi head can be modified to accept the efi manifold
just takes a bit of thinking and some careful grinding with either an air tool of a mini grinding tool
dont attack it with a drill with a cutting bit , you need to control the porting and cannot do this with a drill
a decent match port will leave you with a solid 2mm sealing surface at the top
use a efi inlet manifold gasket to scribe onto the head , do the same on the inlet manifold
you do not need to port all the way up for the injectors as the do not touch the head but rather they have some clearance before the head.use the inlet manifold with injectors to check clearances as you go
while you are at it , clean the casting marks off and remove all rough marks in the ports , blend in all edges , polish the exhaust side. do not polish the inlet side , it must be rough
basic port and polish as above!!!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
