Safe Boost?
Old Sep 12, 2007 | 10:15 AM
user 769729789's Avatar
user 769729789
Default Safe Boost?
Currently on standardish boost at 7psi.
-31 Actuator
Pace Half width cooler
Turbosystems stage 1 chip
Turbo Technics Stage 1 Turbo
Pipercross cone filter
Full Magnex system
Bailey D/V
Making 150bhp ATW on this spec.
Well serviced, always good oil used.
Proffesionally set up by AVA and its recently had new leads and a radiator. Also have the fan on a switch in car so temps are somewhat manageable.
Would about 1bar or 14psi safe for my spec? What would you reccomend?
Old Sep 12, 2007 | 12:59 PM
T28 RST's Avatar
T28 RST
Ok then
14psi will be fine
Old Sep 12, 2007 | 03:37 PM
Oranoco's Avatar
Oranoco
14psi should be no problem but the PACE half width cooler is only marginally better than standard so watch those ACT's
Old Sep 12, 2007 | 03:48 PM
gaz s1's Avatar
gaz s1
As above get a front mount and wind the boost up safely
Old Oct 13, 2007 | 08:38 PM
kiddie's Avatar
kiddie
but why didn't ava set boost higher when it was tuned?
Old Oct 13, 2007 | 09:13 PM
rapidcossie's Avatar
rapidcossie
thought alan turned the boost up?
Old Oct 13, 2007 | 11:34 PM
Chris69's Avatar
Chris69
if u've had it setup at ava shouldn't they have set you boost level to the fueling its setup for
Old Oct 14, 2007 | 05:52 PM
rapidcossie
i was at AVA as coldos car was getting setup and as far as I can remeber the boost and fueling was set.
Old Oct 14, 2007 | 10:26 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default Re: Safe Boost?
-31 Actuator
Full Magnex system
Bailey D/V
u sure youve not turned the boost down, 150@wheels with 7 psi sounds way off,youd prob see that at 12-14psi of boost,best bet is get it booked back in and tell them you want the boost up a bit and they will tell you how much boost can be run safely,i reckon youll make around 150@wheels on 14psi(provided you take the cone filter off as thats stage 1 power and boost,your acts are gonna start creeping into the 70 at least so more boost wont actually make more power,front mount needed to go beyond this
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
