Thermostat housig to the block!
Good afternoon,
Basically snapped a bolt in the block from the thermostat housing, tried drilling it out, made it worse, is there anything i can do to rectify the situation, other than change the block? The bolt is near enough flush with the block, with just a little hole that i tried drillin, but wanted to see if you guys knew of anything before i end up throwing a paddy!
Basically expecting the worst but any help would be great!
Cheers,
Dumpy
Cheers,
Dumpy
#1 in Spelling Club
Firstly, the Thermostat housing bolts to the head, which is bad, but not as bad as if it was the block.
I reckon you will end up taking the head off and taking it somewhere to be sorted. I guess worse case scenario they would be able to drill the remains of the bolt out then fit a larger insert, but then if its a standard head, you might be best to just buy a second-hand head.
i used what i thinks called an "easy out" to remove a snapped temp sender unit. it looks like a taperd drill bit with a reverse thread, as u screw it in anti-clockwise it grips and unscrews the remaing thread.
worked for me without removing anything so could be you ticket to an easy way out!
