ABS LIGHT STAYING ON
MIGHT SOUND A SILLY QUESTION, BUT FOR WOT REASON WOULD THE ABS LIGHT ON MY TURBO STAY ON, USUALLY GOES OFF WHEN I RELEASE THE HANDBRAKE BUT NOW STAYS PERMANTELY ON, ANY IDEAS ANYONE?
S1 Database Editor
IT'S YOUR CAPS LOCK BUTTON. SWITCH THAT OFF AND ALL WILL BE WELL.
Seriously tho..it will either be your ABS belt has snapped and caused the light ot go on or more probably your ABS sensor has fallen out of the casing. Look under the car and see if you can see a switch dangling on a cable. If so, then your sensor has fallen out. Just silicon it back on (silicon around the edges) and it will be fine. Ideally needs to be on a ramp for easier fitment and to see what goes where but can be done from the top if you know where you are going.
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
The Enigma
12-09-2015 10:12 PM
