Lights problem
Old Jul 30, 2007 | 01:40 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Lights problem
Light on my S2 have just started to play up - side/dipped lights work ok on the first notch of the switch and main beam lights work but normal driving headlights do not any ideas anyone ?? I have checked fuses etc and seem ok
Old Jul 30, 2007 | 04:00 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Relays mate
And the wiring to the fuses/relays may be a bit weak.
Ask RST-Steve on here - he's just had the same
Old Jul 30, 2007 | 05:00 PM
RST-Steve's Avatar
RST-Steve
Yeah, just had the same problem fella.... i was driving along at night last Sunday, and then it suddenly all went dark!!!
I still had side lights, but the headlights didn't work at all!
It was the relay that had blown, inside the fuse box!
Old Jul 31, 2007 | 09:14 AM
s2turbsZVH's Avatar
s2turbsZVH
Cheers for the advice
What colour is the relay ? - I have a box of relays but not sure which is whch.
Old Jul 31, 2007 | 03:25 PM
RST-Steve's Avatar
RST-Steve
It's the white one
Old Jul 31, 2007 | 05:01 PM
Daz-rst's Avatar
Daz-rst
make sure you check the wiring as well cause on steves it burnt out the the wiring as well. cheap as chips to fix luckily
Old Aug 1, 2007 | 10:22 PM
mentalasanything's Avatar
mentalasanything
The problem I had on mine wasn't that the relay had blown, but the contacts were loose. I squeezed them together using pin nosed pliers and also slightly twisted the relay contacts, been fine ever since!
Lee
Old Aug 2, 2007 | 12:08 PM
s2turbsZVH's Avatar
s2turbsZVH
Checked my relays last night and the ones that seem to relate to the lights are yellow not white (am I looking at the wrong relay ??)
p.s. in the fusebox where is the relay I am looking for located ? there are two white ones at the bulkhead end of the fuse box - is it those I should be looking at ??
Also I heard the problem could be the switch - is that possible ??[/quote]
Old Aug 2, 2007 | 12:17 PM
RST-Steve's Avatar
RST-Steve
Yep, could also be the switch!!??
When mine blew, i was initially told it was either the relay or the switch!
Seems a VERY common problem now, due to the age of the cars!
Old Aug 2, 2007 | 12:56 PM
CARL B RST's Avatar
CARL B RST
I also have this problem (although touch wood, seems not to have played up recently)
Changing the white relay in the top corner used to sort it for a few months at a time, but the terminals in the fuse box get abit weak aswell, so it might be worth checking that they are making good contact with the relay terminal.
Old Aug 2, 2007 | 03:33 PM
s2turbsZVH's Avatar
s2turbsZVH
Cheers peeps - all help appreciated - I have just noticed that the top corner white relay has had the wire from the fuse box soldered to it so I think I have found the problem - obviously had a weak connection in the past and has been soldered to get round the prob as a temp fix. I will see what I can do with it now and hopefully that will solve the prob
Old Aug 3, 2007 | 11:58 PM
s2turbsZVH's Avatar
s2turbsZVH
Probelm solved
It was the white relay in the top corner - in the end just a bad connection in the fuse box
thanks for the advice - saved me a lot of trouble
Old Aug 4, 2007 | 12:01 PM
mentalasanything
Glad to hear it mate. I hate it when people bodge things like that just to get them working ASAP why not do it right first time, it'll last a lot longer! My bro is like that "sling a wire across here to there...." and a few of my mates, then I end up coming round and replacing burnt out wires etc and doing it properly
Lee
Old Aug 4, 2007 | 04:53 PM
cossieboyIOW's Avatar
cossieboyIOW
happened to me as well lol
Old Aug 4, 2007 | 08:44 PM
Oranoco's Avatar
Oranoco
That's the only electrical gremlin my S2 has had. Was just a crappy contact on the fuseboard with the relay
Old Aug 20, 2007 | 10:26 PM
Robs Frst's Avatar
Robs Frst
Im am also having this problem found alot of corrosion. cleaned it up. My indicator lights work only one of my brake lights work and my reverse light will not come on. also my headlights dim when on full beam.
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
