S1 RSt QUICKSHIFT
Old 24-09-2004, 10:14 PM
vx220
vx220's Avatar
Default S1 RSt QUICKSHIFT
just got S1 RSt, gear selection a bit fiddly, especially between 2nd to 3rd.
i seem to remember a similar problem on my XR3i a long time ago. i
think we changed a nylon ball on the lever? can't remember if we changed whole lever or just ball...
anyway, if i go for a quickshift kit, will this sort it out? B&M do one for about £170, seen good reviews, rally design do one at only £60ish. is this as good? or are there any others you could recommend?
cheers,
Dylan
Old 24-09-2004, 11:18 PM
Alan s1
Alan s1's Avatar
hi m8 i think the b&m ones a seposted to be the bolloxs m8 had one on his vts and it was spot on loads better then his standard leaver
Old 24-09-2004, 11:23 PM
vx220
vx220's Avatar
thanks mate, anyone else?
Old 25-09-2004, 05:34 PM
TILLIO
TILLIO's Avatar
The s1 selectors go sloppy, as the return spring sits in a plastic holder, which tends to break.
I've fitted (but never used ) the B&M on my car, makes the gear selector nice and tight again tho
he B&m comes mainly pre-assembled, and take 20 mins to fit, where as the cheaper kit i believe you have to use mose of the existing parts, and drill/cut bit about
Old 26-09-2004, 11:40 AM
sm
sm's Avatar
get the b&m one i couldnt belive the differnce it made when i fitted mine and its all pre assembled u just have to connect ur selector rods to it
A.t.p
23-10-2015 07:54 PM
07-10-2015 12:56 PM
A.t.p
29-09-2015 05:04 PM
`spotty
25-09-2015 11:41 PM
Billy_RS
13-09-2015 04:17 PM
Quick Reply: S1 RSt QUICKSHIFT
