Stoppers.
Old Jan 14, 2004 | 07:03 PM
Stoo's Avatar
Stoo
Default Stoppers.
Hi,
Anyone got any recomendations for a brake upgrade?I allready have cross drilled/grooved ones but fancy something bigger.
Not particular about wanting to keep standard calipers though.
What size are St170 discs?Can you buy 4Pots for an RS Turbo?
Same for rears,any help would be appriciated guys
Old Jan 14, 2004 | 09:04 PM
Exeter J's Avatar
Exeter J
Anythings possible - depends on how much dosh you wanna spend.
The cheapest option is the cossie disc conversion is Ł145, 283mm and fits under standard wheels BUT retains original calliper!
Think ppl have had the st170 brakes done for Ł300 to Ł400, I know these are bigger but not sure if they keep the same callipers, and doubt they fit under 15s.
Old Jan 15, 2004 | 08:11 AM
RS-adam's Avatar
RS-adam
I got a bracket kit so I can get cossie discs on my S2... and still use my S2 calibers.. But.. what should I buy the dicsc from.. a 2wd or 4wd?? og just buy them a www.mad-for-it.com???
cheeRS
Old Jan 15, 2004 | 08:38 AM
2WD m8!
Old Jan 15, 2004 | 08:39 AM
RS-adam's Avatar
RS-adam
tanx m8... but why 2wd.. and not 4wd... just asking
Old Jan 15, 2004 | 11:55 AM
4WD has a slightly smaller diameter and I think (but don't know for sure) a different offset as well...........
Old Jan 16, 2004 | 04:56 PM
Stoo's Avatar
Stoo
Cheers,
Are the Cossie discs you buy from MadForIt Cross drilled/Grooved?
Anyone tried HiSpec Big disks?
Old Jan 17, 2004 | 12:23 AM
Just got a pair of Focus ST170 calipers for my car...still waiting for the arrival of the 17" rims and discs before i fit them...
apparently they are meant to be a bit more responsive than the Cossie setup but again i have no first hand experience of this to date...will let u know how i get on next week hopefully!
As for the back...im going for a Escort Cossie rear braking setup...should be much more than upto the job also gona be using a bias valve which is a MUST!...the only reason for me changing to the discs setup on the rear is coz im getting them for free otherwise i would have stuck with drums at the back
bassboy
P.S another bit of advice...if u are gonna go for the Cossie or ST170 route...then stick with original pads and discs...they are gona be the best!...although some people may have different views of which pads to go for...IMO standard is best...
Old Jan 17, 2004 | 04:41 PM
Stoo's Avatar
Stoo
Nice,
Let us know how you get on then
Old Jan 17, 2004 | 05:01 PM
Exeter J's Avatar
Exeter J
They are drilled mate... this is the conversion on mine (on mad for it's roller) - You can't make the drilled hole out - cos the wheels/discs are going around at time of photo
BTW Would agree on having standard pads - the race spec/uprated ones need the car to be driven hard ALL the time - as they have to be hot to work well.
Old Jan 17, 2004 | 05:27 PM
Stoo's Avatar
Stoo
Nice one! Just ask for 2wd cosworth discs and brackets to fit an S2?
What are MFI opening times?Just usuall Mon-Sat 9-5 id imagine?
Thanks
Old Jan 17, 2004 | 05:37 PM
Exeter J's Avatar
Exeter J
Just ask for the RST to cossie disc conversion - check www.mad-for-it.com (although i think they've updated the website and much of it is still in under construction).
9-5, No - Colin doesn't get out of bed till 9:30am - Lucky git eh - LOL
Opening times are 10am til 6pm Monday to Saturday.
Old Jan 17, 2004 | 05:51 PM
Stoo's Avatar
Stoo
Yeah,lucky sod.I start work at 8am
Anyway,thanks for your help buddy ill phone them on Monday morning
Old Jan 17, 2004 | 09:10 PM
chewyS2RST's Avatar
chewyS2RST
get a set of these,u wont be dissapointed
pics a bit blurry
Old Jan 17, 2004 | 09:28 PM
Six pots eh? greedy git!,Goin for cossie ones meself,except just had to fork out on water temp sensor,fan switch...car over heated the other day and found oil coming from rocker cover when i was chaging the sensors! ,but shouldnt over heat no more!,also just had to buy steering rack!...Bloody RS costing me a bomb!...oh and i found water on the floor today that has come from some where on my car!Gutted gotta sort that now!...and to top it all (goin on i know)...was driving down the road the other day and someone decided to throw a stone off there tyre into my HEATED window screen and cause a nice crack in it!!!! And its MOT time next month...grrrrrrr
Old Jan 18, 2004 | 08:09 AM
Exeter J's Avatar
Exeter J
Nice brakes Chewy - would love some of those but ŁŁŁ is a bit limited at the mo.
Old Jan 18, 2004 | 08:43 AM
chewyS2RST's Avatar
chewyS2RST
Sounds like you are having a mare james
Im sure it will get sorted mate
Exeter j
Old Jan 18, 2004 | 09:32 AM
james...might be able to get u a good price on a heated sreen if ur interested...PM me
bassboy
Old Jan 18, 2004 | 03:42 PM
escortmad79's Avatar
escortmad79
My Series 1 has Wilwood 4 pots fitted to the front
Old Jan 19, 2004 | 05:33 PM
bassboy, is this a pm? aint got a clue...lol...how much for the screen and how much do they cost to fit?!!!!
B19LRW
32
Jan 30, 2012 11:34 PM
