mocal oil temp gauge
Best way is to fit a boss in the sump, but will need removing for a boss to be welded.
This is the one i done on my xr2t.
if not fee'sable then as Rick said.
you wont be able to get a mocal, racetech or similar capilary temp gauge sensor thro a m14 sump plug hole.
the adapters that can be brought are for a smaller electric gauge sender.
As above, Tweeks or Burton Power should be able to help.
You need one of these...
Found here - https://www.burtonpower.com/
Under - Instrumentation - instrument accessories
Thats for the oil pressure.
It only allows for a extra 1/8 fitting after the oil pressure switch is fitted. A mocal oil temp is a 3/8 fitting.
t pieces i use are from a local pneumatics place, but i have no idea what the size is. It's the same as the one for the oil pressure switch - m12?
I had some adaptors that sleeved it down to 1/4 and 1/8NPT.
Oil temp should really be measured in the sump,as thats where the main body of oil will always be.Just drill and tap you're sump and fit the senser there for the most accurate readings.Regards,Micky
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
