Crossover pipe
Old Apr 13, 2007 | 09:21 PM
T28 RST's Avatar
T28 RST
Ok then
Default Crossover pipe
My crossover pipe sits rather close to my manifold, its even started to melt a hole in it
Can i get one made up that a different shape and routes it away from the manifold.
What designs do you think would work
Old Apr 13, 2007 | 09:42 PM
Rick's Avatar
Rick
change to a 3i manifold - would be easiest
Old Apr 13, 2007 | 10:32 PM
djmillsy's Avatar
djmillsy
Fife Radge
see ava theyll make you one up
Old Apr 13, 2007 | 10:40 PM
T28 RST's Avatar
T28 RST
Ok then
Already spoke to them and didnt like the design they suggested
Old Apr 13, 2007 | 10:43 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
3i, like rick says
Old Apr 13, 2007 | 10:44 PM
T28 RST's Avatar
T28 RST
Ok then
Is it a striaght fit, if not what needs doing
Old Apr 13, 2007 | 10:56 PM
Charlie Chalk
Unknown.
Needs modding for the TB, other than that.. Im sure its a straight fit
Ask Christian, He has the conversion
Old Apr 13, 2007 | 10:58 PM
T28 RST's Avatar
T28 RST
Ok then
Old Apr 13, 2007 | 11:38 PM
Charlie Chalk
Unknown.
Only thing with Christians, Is the Injector ports would have been machined, as he is on OMEX..
Originally Posted by Christian and Beccy
Here is the engine in place and 95% finished. I just have a few loose ends to tie up.
I started to fabricate a Throttle Cable bracket today and have an Inlet Pipe on its way from Pro Alloy. I also have a remote Fuel Pressure Regulator to fit.
Here you can see the Injector mounting and the spangly wiring loom braiding. Man, that was time consuming!!
Hoping to turn the key over the weekend.....
Old Apr 14, 2007 | 07:59 AM
djmillsy's Avatar
djmillsy
Fife Radge
that looks stunning
Cosnada
Jan 7, 2016 05:30 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
