Problems with a S2 stalling
Just had a call from a mate. He's having trouble with his S2 stalling. It will only do it when its idleing!" The engine will be running fine and then it will just die like someone has turned the key
does anyone have any ideas....? If you try startin the engine again, it will fire up fine. I am completely stupped
Originally Posted by MJC
Wouldn't an air leak be a constant problem....? the engine runs fine and then randomly just stalls
check all boost/vacuum hoses also check the brake vac hose,there renowned for cracking splitting and leaking air
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
