management 2.0zvh
management 2.0zvh
Hi all..
Finally decided to go efi on my 2 liter zvh turbo
Started to collect the stuf needed,,,
Only have to decide if to go ofab or cosworth..
What's best and easier to fit.
Has to run about 1.3-1.5 bar of boost..
what cosworth ecu's can i use?
Is a cos ecu with stage 1 also useable for my zvh or do i need a custom map?
And what about ofab..... get a costum chip or something else
Finally... about injectors... the blue escos can cope with 280 bhp or so..
Should i get them or go for some greens instead?
thanks all
cheers,
Gregor
thanks all
cheers,
Gregor
Re: management 2.0zvh
Originally Posted by Gregor
Hi all..
thanks all
cheers,
Gregor
thanks all
cheers,
Gregor
Hi all..
thanks all
cheers,
Gregor
thanks all
cheers,
Gregor
If it comes out as you say ofcourse i'll go for an aftermarket management but i don't see cos management coming out as expensive as you say?
And i'm not from UK so fitted and mapped wil be a bit of a problem
ive gone cossie, cant see how its £1500 tho!! paid £250 for ecu and £35 for the wiring loom!!! everything else, you would have to buy anyway, whatever management u were using ie injectors, sensors, pullies, triggers etc...
ive got efi already, if i go cossie can i use my efi inlet and 1.8 cvh crank pulley for the trigger? and all i need is cossie ecu and loom?
need to have wasted spark driver installed into ecu to run fiesta coilpack, in which case youll need a cam sensor or u have to use a hybrid dizzy affair, cvh shaft mated to a cossie dizzy...
Already got the injectors ( blue cos ) efi flywheel, inlet manifold , fuelrail and harness. and most sensors....
just an ecu and wiring and a chip so i can run on the fiesta coil....
But a aftermarket fully mappable would be the greatest but comes with a pricetagg...
level 8 cossie is 3d mappable i believe... sure ill be corrected if im wrong but i was told that, thats why i went with that rather than level 6... level 8 will also run the lambda sensor which level 6 doesnt....
mk3ste
17-10-2021 10:09 AM
deathrider666
28-09-2015 06:12 PM
