electronic boost controller
Old Jan 29, 2007 | 11:43 AM
rsdan's Avatar
rsdan
Default electronic boost controller
took my car to get it set up the other day, first time since its had an engine rebuild, and its not holding the boost. they said i need an electronic boost controller n that once i get one my s2 will be good for 200bhp.
can any1 suggest a good 1, where i can get 1 and roughly how much they are plz.
cheers
Old Jan 29, 2007 | 11:57 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I have to say that I am a great believer in Boost Controller's, but I suspect in this case that there is anothe reason for the boost control problems that your tuner is having.
There is a common misconception that a Boost Controller will work miracles. It won't.
I run a 24psi actuator on mine (consider that a -34 is around 15psi) as that is the only way we have been able to control a fairly stable 30psi.
Old Jan 30, 2007 | 09:18 AM
orion_rst's Avatar
orion_rst
Time to play The Game HHH
I agree. It sounds strange that it's because you need an electronic boost controller. However I can suggest you Blitz DSBC. I've got one on my RST. It's great. It has got 4 different pre-set settings which you can adjust to your needs. It has also more functions to eliminate boost spikes and lag... which I haven't yet tested because I'm still doing my engine running-in after re-building it
By the way can anybody tell how many miles do I need to make engine running-in after a full engine re-build? Thanks
Old Jan 30, 2007 | 12:40 PM
Badman38's Avatar
Badman38
christian so your lowest boost setting is 24psi? because i run a -31 but with 28psi could this be the reason why i dont always hold 28 at high boost. i currently use a turbosmart controller series one but i need to start running progressive boost can you recommend a boost controller for me i know the turbosmart eboost2 does the job are there any others, plus is it possible to run an actuator like yours with progressive boost.
thanks
sean
Old Jan 30, 2007 | 02:12 PM
Christian and Beccy
#1 in Spelling Club
Sean, I haven't split hairs with boost delivery, I am more worried about making high boost numbers reliably and that is the reason for going for a harsh actuator.
My controller is a Blitz SBC I-Color and I am pleased with it. The SBC-ID range are just as good from a control point-of-view as they use the same dual solenoid system.
Peeps on here do tend to like E-Boost though, so there's that option if you want to follow the masses!!
Incidentally, a 24psi Actuator will usually result in a lower low boost setting than that, but I haven't had much of a chance to analyse that as I fitted only a short while before the Thrash and the car still isn't fixed!!
I have still had to use high duty numbers in the controller to make 30psi.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
