dumb question
Old Oct 4, 2006 | 10:48 PM
Diamonds.'s Avatar
Diamonds.
Default dumb question
is this where the injectors are?
cause when i 1st start her up she doesnt run on all cyclinders unless i hold her just under 3k for a little while. never used to do this. but when i went Power Engineering last and also said by mates it sounds like an injector. well today i had a nose and the one on the right was loose i havent fiddle with it yet but just want to find out before i do tighten up or replace them all.
cheeRS
Rob
Old Oct 4, 2006 | 11:07 PM
gambit's Avatar
gambit
Default injectors
yep thats where they are mate, at the back of the rocker. I think they are held in by 8mm nuts and they also have a special type of washer. Very easy to remove but make sure they are seated correctly when refitted, the washers must sit flush with the joining surface.
Old Oct 4, 2006 | 11:22 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
maybe the rubber boots are ruined, you can still get them ,try ebay.or ford.
Old Oct 4, 2006 | 11:23 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
check that timing belt, looks fairly well used?
Old Oct 5, 2006 | 12:25 AM
Diamonds.'s Avatar
Diamonds.
vroooom ptssssh thank you mate yeh it does need to be changed ASAP. would that cause any problems with whats happen at the mo? ps i know what probs i would get if it snaps...not good things
akito-man are they the washers then that fit between the injector and the engine?
gambit thank you for the info thats a great help too
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
