EFI conversion
Old Jun 8, 2006 | 09:02 PM
TURBO BOI's Avatar
TURBO BOI
Default EFI conversion
im shortly about to carry this conversion out, im going to use my erst head with a adaptor plate for the frst mainifold.
does any 1 know if i need any other adapter plates other than the inlet plate?
has anyone carried out this efi conversion?
also when the conversion has been carried out, what mods will i need for around 180bhp. a stage 1 turbo will be going on aswell
Old Jun 8, 2006 | 09:07 PM
Wazzzer's Avatar
Wazzzer
nope you'll just need the inlet plate for the injectors
did this conversion myself and VERY happy with it
Old Jun 8, 2006 | 09:11 PM
ian r's Avatar
ian r
just got mine running easy conversion to do when u get the right information mine is on a ofac ecu and will be running beige injectors and a 195 chip any questions just give me a shout
Old Jun 8, 2006 | 09:13 PM
TURBO BOI's Avatar
TURBO BOI
which way did you do it wes? frst flywheel or 1.8cvh cps sensor and crank pulley? do i need a frst throttle pedal and cable?
Old Jun 8, 2006 | 09:14 PM
TURBO BOI's Avatar
TURBO BOI
is that all your mods? chip and injectors? for 195bhp?
Old Jun 8, 2006 | 09:15 PM
ian r's Avatar
ian r
xr3i cable and pedal i used and the sierra cps havent thought the mods through properly yet thats just my rough idea i have
Old Jun 8, 2006 | 09:18 PM
ian r's Avatar
ian r
forgot my car has piper285t2 cam 1800 bottom end stg2 turbo grs intercooler -34 actuator etc
TURBO BOI's Avatar
TURBO BOI
im going that route too
is xr3i cable n pedal different to rs turbo then?
where did you get ur adaptor plate? was it supplied with gaskets?
what spec are you running ian?
Old Jun 8, 2006 | 09:23 PM
ian r's Avatar
ian r
adapter plates are cheap from area-six think gaskets r extra
pedal needs to b changed cos the cable has different ends
Old Jun 8, 2006 | 09:33 PM
TURBO BOI's Avatar
TURBO BOI
oh i see
what about rocker cover and charge pipe? need diff ones or they ok?
Old Jun 8, 2006 | 10:27 PM
tim10_10's Avatar
tim10_10
What do you do with regards to wiring up ecu relay and fuel pump relay as im going to be doing this to my mk3. Also I take it the rev counter will then be wrong due to the dis unit?
Old Jun 8, 2006 | 10:38 PM
TURBO BOI's Avatar
TURBO BOI
Q: Do I need an EFi dash pod for my car?
A: No, you can run a wire from pin 11 on the E-DIS unit, to the back of your dash pod, to the tachometer input. This will give you a clean RPM signal.
this above is at the bottom of the page on this link
http://www.rsbible.co.uk/
Old Jun 9, 2006 | 02:41 PM
TURBO BOI's Avatar
TURBO BOI
how can i get the chatter (compressor stall) when everything is up and running?
Old Jun 9, 2006 | 02:50 PM
notSteveS2's Avatar
notSteveS2
by makin sure there is no crappy dump valv on it and just air filter off the turbo...
u can get 180bhp easily matey...
bout 14psi... -31... chipped ecu... bout do ya then!
Old Jun 9, 2006 | 02:54 PM
TURBO BOI's Avatar
TURBO BOI
Wkd, so no need for beige injecters? you running efi steve?
Old Jun 9, 2006 | 02:57 PM
notSteveS2's Avatar
notSteveS2
yea u need bieges too matey
yea im runnin cossie management matey!
Old Jun 9, 2006 | 02:59 PM
TURBO BOI's Avatar
TURBO BOI
cool, cossie management much agro to fit? which inlet did you use for that?
Old Jun 9, 2006 | 03:18 PM
notSteveS2's Avatar
notSteveS2
i didnt fit it myself but have took it out and put it bk in...
theres loads of different ways it can b done... but there is alot of custom stuff needed so it isnt easy...
not cheap as fezzy managemnt swap neither...
i use a modded fezzy inlet manifold.
Old Jun 9, 2006 | 05:38 PM
Rab's Avatar
Rab
Fucking superstar........
Mate, as I did this conversion myself I'll help you through it as you go. I learned alot when I did mine, and I have some wiring diagrams that'll probably help you out
Old Jun 9, 2006 | 05:39 PM
Rab's Avatar
Rab
Oh, and have a look here
https://passionford.com/forum/viewtopic.php?t=202890
Old Jun 9, 2006 | 05:46 PM
TURBO BOI's Avatar
TURBO BOI
thanks
Old Jun 9, 2006 | 08:30 PM
TURBO BOI's Avatar
TURBO BOI
im doing the 1.8cvh pulley way, do i need to change the alternater pulley aswell? and run the 1.8cvh alternater belt?
Old Jun 9, 2006 | 08:50 PM
ian r's Avatar
ian r
u need the alternator bracket and adjuster arm off the sierra cvh my alternator i just changed the alternator pully an it aligned spot on its safer to get the sierra alternator though that way it will deffo fit
Old Jun 9, 2006 | 08:53 PM
TURBO BOI's Avatar
TURBO BOI
ok cool
you used a EFAB ecu and loom didnt you ian r?
Old Jun 9, 2006 | 08:55 PM
ian r's Avatar
ian r
i am using xr3i efi loom ofac ecu and map sensor
Old Jun 9, 2006 | 09:01 PM
TURBO BOI's Avatar
TURBO BOI
i am using xr3i efi loom ofab ecu and map sensor
going to be doing mine with EFAC loom ecu and frst mainifold
am i right in thinking that i wont need to do as much chopping and changing as you did ian with ur xr3i loom?
Old Jun 9, 2006 | 09:30 PM
ian r's Avatar
ian r
xr3i efi is a straight fit no chopping for me just extended a few wires and the ecu is inside the car now
you mean ofac not efac
Old Jun 9, 2006 | 09:33 PM
TURBO BOI's Avatar
TURBO BOI
oh yeh ment OFAC
Old Jun 10, 2006 | 12:01 AM
TURBO BOI's Avatar
TURBO BOI
will a 1.8cvh alternater bolt straight on, is the adjuster arm to tension the alternator belt?
Old Jun 10, 2006 | 05:08 AM
ian r's Avatar
ian r
the sierra alternator will fit straight on with the above brackets the adjuster arm is to tension belt
Old Jun 10, 2006 | 09:47 AM
Wazzzer's Avatar
Wazzzer
I used a fiesta turbo block so it had the EFi flywheel and CPS already there
if you keep the escort turbo charge pipe you will need to get a bit of Samco that will reduce the sizes down (the fiesta turbo throttle body is bigger)
any more questions just give me a shout
Old Jun 10, 2006 | 10:30 AM
TURBO BOI's Avatar
TURBO BOI
im sure there be plenty more questions when i get going cheers
Old Jun 10, 2006 | 10:32 AM
TURBO BOI's Avatar
TURBO BOI
thanks, if i choose just to use the 1.8cvh alternator pulley on my 1.6 alternator, will it be a straight swap and then the pulleys will line up? or will it need spacing out ect
or if i use the whole 1.8cvh alternator can i tension the belt the same way as before ? or will i need to fit and use the adjuster arm?
Old Jun 11, 2006 | 08:10 PM
turboash's Avatar
turboash
Default efi
could someone tell me the differance between ofac an ofab ?? also are there any wiring diagrams i.e which wire connects to where as i am about to do theis conversion aslo
Old Jun 11, 2006 | 11:05 PM
reality's Avatar
reality
Default Re: efi
OFAC uses digital map sensors (2 bar).. OFAB uses analogue (eg, cossie type, 3 bar etc.).. OFAB makes life easier tuning..
Old Jun 12, 2006 | 04:24 PM
Schmidi's Avatar
Schmidi
Default Re: EFI conversion
You wrote nothing else is needed.
Doesn't it matter that in the EFI head inlet ports, there are places drilled in for the injectors, and in the KE-Jet head there are none?
Is it noticeable, that the injectors are not so close to the valves, and do not inject diretly to them?
Old Jun 12, 2006 | 04:38 PM
TURBO BOI's Avatar
TURBO BOI
Heres the plate im getting
the adapter plate isnt just made for the mainifold to fit the head, in the yellow circles your see machined grooves for the fuel to go through and is aimed into the cylinder and no all over the plate
is that what you was worried about?
Old Jun 12, 2006 | 04:44 PM
Schmidi's Avatar
Schmidi
Yes, this is what i was asking. You say, with this plate, you get the same angle for the injectors, as if this grooves were in the head. Fine.
Could you please tell some additional information about it? I think it's made from plans, measurements, not from somebodys own idea about the sizes, angles, etc.
Thanks!
Old Jun 12, 2006 | 04:51 PM
TURBO BOI's Avatar
TURBO BOI
oh i see
i spoke to mike at http://www.ferriday.co.uk/ and he siad hes made loads of these plates (so i asume there tried and tested otherwise there would be afew complaints i think) he hand finishes them aswell around the injector ports
Old Jun 12, 2006 | 04:58 PM
Schmidi's Avatar
Schmidi
oh i see
Thanks, I'll try!
