timing
Old Apr 5, 2006 | 09:11 PM
grunter's Avatar
grunter
Default timing
bit of a basic question really wot should the timing be on a chipped engine???? should it be standard or summat else
Old Apr 6, 2006 | 08:49 PM
grunter's Avatar
grunter
bttt u mean to tell me no one knows??????
Old Apr 6, 2006 | 09:09 PM
Micky's Avatar
Micky
I have'nt a clue,good question but.Regards Micky
Old Apr 6, 2006 | 11:20 PM
infinityMJD's Avatar
infinityMJD
just a guess, but on idle should be standard and the advance should go beyond the normal on acceleration, chiped engines rev higher and more freely so would need more of an advance to facilitate, just an educated guess mind you
Old Apr 7, 2006 | 05:46 AM
grunter's Avatar
grunter
thats wot i was thinking also was just a general question cos i was having a fiddle with mine the other day to see if i could loose the flat spot ive got
Old Apr 11, 2006 | 10:09 PM
biglee's Avatar
biglee
Audio specialist
13 degrees BTDC on idle standard ,and depending on the make of your chip its usually 12 or 11 d.BTDC
Old Apr 11, 2006 | 10:20 PM
Andy_R's Avatar
Andy_R
More boost less advance. More advance less boost! Sounds straight forward enough the real skill however comes in finding the optimum ballance!
It all depends on who has set your car up & their preferred method of optimising your power as to whats best for your car.
Old Apr 12, 2006 | 09:01 AM
barry0777's Avatar
barry0777
witch ways advance and retarding these engine???
Old Apr 12, 2006 | 09:39 AM
sime73's Avatar
sime73
when using a 285t cam its 119 atdc
Old Apr 12, 2006 | 11:24 AM
SafeChav's Avatar
SafeChav
119 degrees...........are you deadly sure about that
Old Apr 12, 2006 | 01:59 PM
biglee's Avatar
biglee
Audio specialist
ooopppps dont think it will burn too well at that ....lol
Old Apr 13, 2006 | 09:48 AM
barry0777's Avatar
barry0777
so witch is it then???
Old Apr 13, 2006 | 09:49 AM
SafeChav's Avatar
SafeChav
Around the 13 degree mark but every engine is different, the best way is to get your car tuned........
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
