CV Boots?
CV Boots?
Hello all! Where do you lot go when you need new CV boots for your EsCos's because I'm having no luck whatsoever at my local Ford dealer?!
The inner cv boots are finis code 6672258 Ł23.66.they are available from germany about 5 days from your ford dealer (if they havent got them in stock already!) hope this helps.
Resident Wrestling Legend
about Ł3 from round the corner from my house
if you go to a motor factor to get them, make sure you take your old one with you, the books list them as a different size (smaller and shorter) than the one you need
i got one from Fords today without any problems,i only changed it last month and its already split I guess my engine mounts have worn,i just ordered a set of vibra technic engine mounts,any one run these on thier esc cos? and if so are they O.K?
07-10-2015 12:56 PM
chris m1
07-09-2015 08:02 PM
