BLOCKED MONGOOSE ?
BLOCKED MONGOOSE ?
AS TITLE HAS ANYONE EVER HAD A MONGOOSE EXHAUST BLOCK ON AN ESCORT COS AS I TOOK MINE FOR A SPIN THIS MORNING AND ALL WAS FINE IT WAS RUNNING 1.3 BAR OF BOOST AND DRIVING FINE I HAD A BIT OF A PLAY WITH A ROVER 220 TURBO FOR A FEW MILES THEN THE BOOST DROPPED DOWN TO ABOUT 0.8 BAR AND IT KEEPS MAKING A NOISE LIKE THE EXHAUST IS BLOCKED UNDER THE SEATS EVERY TIME THE CAR COMES ON BOOST I HAVENT HAD TIME TO STRIP THE EXHAUST OFF YET TO SEE IF THAT IS THE CAUSE BUT I DONT NO WHAT ELSE COULD BE THE CAUSE THE CAR IS RUNNING A STAGE TWO GGR CHIP WITH T28 HYBRID TURBO UPGRADED FUEL PRESSURE REG + FUEL PUMP AND ALSO A BIG TURBO INTERCOOLER WITH A PACE CHARGECOOLER UPGRADE KIT ON IT ANY IDEAS APPREICIATED
Re: BLOCKED MONGOOSE ?
I have a Mongoose exhaust and in my limited experience with Cossies, i would be 99.9% certain that your exhaust is not blocked as it if was, i think it would simply cut out rather than under perform.
Check for spark plugs maybe or air leaks, just sounds like something has come off somewhere, but i wouldnt bother taking you exhaust off for sure !!
CHEERS FOR THE REPLIE I HAD A LOOK AT IT AFTER WORK TODAYAND FOUND THAT IT WAS THE BOOST PIPE LEAKING JUST BEFORE THE THROTTLE BUTTERFLY ALL IS FINE AGAIN NOW
richie, when are you bringing yours down so i can have a look then!?
