Reading a fault code but can’t find the definition
Old 09-04-2018, 07:41 AM
Cosworther
Cosworther's Avatar
Default Reading a fault code but can’t find the definition
Just read a fault code on my 1993 Escort Cosworth YBT. It shows 4.4 which I can’t find the meaning. The car now runs smoothly from the start but gets cut at 4K rpm, obviously in limp mode. Any idea? Experts of ecu mostly welcomed!
Old 11-04-2018, 07:44 AM
oldford
oldford's Avatar
Code 4.4 is EEROM (Programming) error.
The EEROM is located inside the CPU chip and is used to store copies of some variables.
Cosworther (12-04-2018)
Old 11-04-2018, 01:25 PM
Cosworther
Cosworther's Avatar
Thank you! The CPU chip you mentioned, is it the Motorola MC68HC11E1? If so,
does it mean my ECU is kind of a walking dead unit? Is it possible to fix?
Old 11-04-2018, 05:08 PM
oldford
oldford's Avatar
Yes, the CPU is the Motorola MC68HC11.
I have no idea about the possibilities in Taiwan.
Are there firms that repair engine controllers? Maybe they can get a replacement CPU.
That is, if they are even sold now, because it's a very old chip.
Old 11-04-2018, 05:16 PM
martysmartie
martysmartie's Avatar
As Oldford says I am doubtful that you can get another CPU, due to the age.
ECU's can still be got hold of, but sadly there will become a time when they become extinct.
Martin
Old 11-04-2018, 05:47 PM
Cosworther
Cosworther's Avatar
Thank you very much, Oldford and Martin. Yes I know it’s very old and may not be able to find the chip here in Taiwan. There maybe only three or four Escort YBT left in Taiwan. Will try to ask some ECU repair shop anyway.
Wondering is it still possible to get the ECU fixed in UK? Or maybe the only way is to buy a used one from someone?
Old 11-04-2018, 06:16 PM
martysmartie
I've repaired them before. However this appears to require a new CPU, so obtaining the part is the issue.
Age is one thing, but also the engines which they manage, namely Cosworth's, some Fiat's and other Italian exotica which means they are as rare as the cars.
I believe you would require another ECU.
Martin
Old 11-04-2018, 06:27 PM
Cosworther
Cosworther's Avatar
Thanks again for sharing this valuable information. I will update progress here if I got any.
Old 11-04-2018, 06:37 PM
Cosworther
Cosworther's Avatar
Hi Oldford and Martin, Do you think these items on eBay works?
https://www.ebay.com/itm/MC68HC11E1-...-/112380109271
MC68HC11E1CFNE2
https://www.ebay.com/itm/19250582497...m=192505824974
MC68HC11E1VFN
Both are 68HC11E1 and looks similar, some printed digits not the same. Are they functionally the same?
The attached photo is the 68HC11E1 in my ECU.
And I found two related datasheets but not fully understand it.
FYI
File Type: pdf
File Type: pdf
Old 12-04-2018, 01:53 PM
oldford
oldford's Avatar
You need the MC68HC11E1VFN or MC68HC11E1MFN.
The latter has a higher operating temperature range. Both can handle a 12 Mhz XTAL.
The MC68HC11E1CFNE2 does not have an extended temperature range, so it could be a problem in hot whether. Also it cannot handle a XTAL higher than 8Mhz.
What does the XTAL have printed on it? I can't remember what it said.
Old 12-04-2018, 03:44 PM
Cosworther
Cosworther's Avatar
Thank you very much for the reply, Mr. Oldford!
Sorry I am not sure which one is the XTAL. Is it the little silver metal parts in the picture I attached? If so, the "W80NDK1X:" is printed on the top surface. BTW XTAL means the crystal, right?
Old 13-04-2018, 06:50 AM
oldford
oldford's Avatar
I am not sure this is the Crystal (XTAL).
I was expecting a different shape. See: http://bigturbo.co.uk/l1ecu.gif
The XTAL is the silver part with a wire soldered over it on the top in the middle next to the 2 screw holes in the casing. Normally the XTAL is very close to the CPU.
Old 13-04-2018, 07:09 AM
Cosworther
Cosworther's Avatar
Yes, it is just beside the CPU. After google the "XTAL" for pictures, I think this is the XTAL. But can't find any information about "W80NDK1X".
Old 20-06-2018, 10:01 PM
midnight_man
midnight_man's Avatar
I am not sure if this is source of your problem....
you can have damaged .bin inside eeprom 27C256.
what specs you are runing? chip? OE?
you need to try burn image into NEW 27C256 or disable checksum controll inside.
But personally I dont think that is the reason for cut in 4000 rpm.!
can be another problem!
Old 21-06-2018, 05:09 PM
Cosworther
Cosworther's Avatar
Thanks for advice. My eprom is stage 1 just bought from MSD. Been tested on another ECU without showing any fault code. That’s why I also think there is something wrong in my original ECU too.
Old 21-06-2018, 05:27 PM
midnight_man
put original chip into ECU....is there 4000rpm cut?
Old 22-06-2018, 08:49 PM
martysmartie
Nope, I would imagine that's overboost protection.
Martin
Old 26-06-2018, 01:09 AM
Cosworther
Cosworther's Avatar
Yes, cut at 4000 rpm. And failt code 4.4 too.
Old 26-06-2018, 08:36 AM
midnight_man
even if you rev engine in neutral on place? without load?
Old 26-06-2018, 08:40 AM
Cosworther
Cosworther's Avatar
Yes. I tested in the garage.
Old 26-06-2018, 08:56 AM
midnight_man
looks like bad ecu....
Old 26-06-2018, 09:17 AM
Cosworther
Cosworther's Avatar
I thought that too. Thanks!
Old 27-06-2018, 07:59 AM
midnight_man
look PM mate
Old 24-02-2021, 08:32 AM
Cosworther
Cosworther's Avatar
Hi oldford, how are you?
I have one more question about the MCU. If I can find a MC68HC11E1VFN or MC68HC11E1MFN and replace it, do I need to do something to the EEROM? such as to store some variables into the EEROM? Or simply replace it on the PCB?
Old 24-02-2021, 09:56 AM
martysmartie
It should just be a case of replacing it.
In theory it will contain microcode, but the actual calibration (i.e. what runs the engine) is stored in the EPROM.
Martin
Old 13-04-2021, 03:12 AM
Cosworther
Cosworther's Avatar
Martin
Apparently, it's hard to find the chips now...I CAN'T FIND IT...
Oggie79
20-04-2017 05:46 PM
devilboy666
20-03-2012 07:07 PM
rich123
13-12-2011 08:42 PM
richm
01-01-2007 09:34 PM
Avinitlarge
29-07-2006 08:09 PM
Quick Reply: Reading a fault code but can’t find the definition
