phase sensor issue.
Old Jul 21, 2016 | 06:15 PM
london_chris's Avatar
london_chris
Default phase sensor issue.
I've a fault with my escort cosworth, p8 ecu.
The ecu went into limp home mode with a forced misfire at 4k rpm. Replace various sensors and finally traced it down to a phase sensor, replaced with a known good sensor....
Car returned to normal with no issues and returned to full power.
250 miles later the same issue has returned. I'm going to replace the phase sensor again but just curious as to whether there is anything I should be checking which would cause repeated phase sensor failure?
Old Jul 21, 2016 | 06:33 PM
costina's Avatar
costina
Live long and prosper!!
Could be just bad luck. But id check the multiplugs by the coil and clean them.
If you still have them that is.
J690Turbo
Ford Escort RS Cosworth
17
Jun 8, 2024 12:46 PM
london_chris
Jul 21, 2016 06:12 PM
Escortdriver1
16
Apr 11, 2016 06:01 PM
clipper49
Mar 10, 2016 09:26 AM
Rs(555)
Feb 28, 2016 08:31 PM
