I have a problem with my Cosworth. I have checked to see if i can find the problem, and i think i know what it is. Pin 20 that is connected to the ECU L8 i need to know where does it go? and to what relay?
Pin 20 as said is the power feed, the power comes via the ECU relay which can be found behind the passenger side dash along with fuel pump relay etc (At least on Sierras they are) it also feeds the injectors and ISCV.
