Escort Cosworth ABS problem
05-03-2010, 09:03 PM
Every know and again i get the hazard light and the ABS light on, and then my brake peddel goes rock solid.
Is this likely to be one of the ABS sensors?
Thanks
06-03-2010, 12:15 PM
Check the wheel sensors & pickup rings on the CV joint. Mine would come on at 70mph & it was down to some damaged teeth on the OS CV joint.
06-03-2010, 05:53 PM
I don't think the brake pedal will go rock solid when a wheel sensors fails.
Could be the electric pump on the unit. They are known to fail.
08-03-2010, 04:48 PM
Thanks for the info, it only ever does it every on the very odd occasion
09-03-2010, 01:00 PM
I have had this problem on some Sierra`s, change pressure switch on abs unit, and it works fine
Vincereese
01-06-2023 09:14 AM
jessie_rs
11
03-06-2019 04:57 PM
James Porter
26-08-2015 10:51 PM
Vincereese
16-08-2015 06:38 PM
Old ford
31-07-2015 06:50 AM
