Escos (big) intercooler size
How big intercooler does fit in Escort Cosworth (non aircondition, T35, 92 model)? What is maximum size? Is there as much room as in Sierra Cosworth?
Originally Posted by Glenn5
as far as i know you can sqeeze in a gen rs500 cooler but you need 2 adapt the pipe work a little its 2 do with the angels going to the turbo
590 BHP/Ton
you can squeze in a 50 mm thick Rs 500 style intercooler if you move the radiator back by about 15mm.
Can be done with the standard fans but it is very tight.
We do one that bolts straight in and we supply the water radiator re- mount brackets with it.
155lee
24-10-2015 11:11 AM
