help fitting a the rubber coupling
Old Jul 12, 2009 | 01:48 AM
florent78's Avatar
florent78
Default help fitting a the rubber coupling
I fit a new rubber couling for the transmission
I've got a little problem :
1 side is stamped "drive shaft side" : so this side should look the rear of the car ; it's ok
but there are 2 type of "hole" for transmission side so you can have 2 positions :
you can see it on the picture
can someone explain me how the rubber coupling should be fitted ?
thanks a lot
Old Jul 12, 2009 | 08:28 AM
It's going to be the same as the one already fitted so just copy the way that is fitted.
Looking at the picture I would assume that one end of the prop that fits to this will have machined lugs that fit into the slightly recessed bearings whereas the other side will not.
Old Jul 12, 2009 | 10:13 AM
florent78's Avatar
florent78
the rubber coupling for the sierra 4WD is different and do not have the machined lugs ...
so don't know how to fit it.
if you see the picture :
need to know if I should use the red or blue holes for the torx studs (coming from gearbox transmission)
and so witch hole (blue or red) to fix the transmission shaft with the studs and nuts
thanks
Old Jul 13, 2009 | 05:20 PM
florent78's Avatar
florent78
up
nobody change it ????
Chas
Sep 21, 2015 08:57 PM
kosienutter
31
Aug 22, 2015 09:55 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 10, 2015 12:08 PM
