Help need this
Old Feb 19, 2004 | 08:07 PM
Default Help need this
right its a fuel line and the finis code is 6730590 im well goosed with out it and Ford dont make them any more and its split on my car and im carless
its number 58
Old Feb 20, 2004 | 06:06 AM
cossymad's Avatar
cossymad
What Dean?
Old Feb 20, 2004 | 03:59 PM
right as above please help me guys
Old Feb 20, 2004 | 04:19 PM
cossymad's Avatar
cossymad
I know what to do...I know what to do
Old Feb 20, 2004 | 04:50 PM
Please do i tell oh and thanks Chris i got all the breather kit today
Old Feb 21, 2004 | 07:00 PM
anyone
Old Feb 22, 2004 | 08:56 PM
Sean Bicknell's Avatar
Sean Bicknell
Which fuel line is it that you want?
If you are talking about the hard pipe feed and return that run under tha car, then give me a call on 0121 557 0202 on Tuesday as I may be able to help you out.
Sean..
Old Feb 23, 2004 | 06:32 AM
Sean..
its the pipe numbered 58 in the pic mate ill see what happens today if i get no joy ill be on the phone tomorrow mate cheers
Old Feb 23, 2004 | 08:14 AM
cossymad's Avatar
cossymad
I posted before you put the picture up!!
I thought you meant the filler neck hose as this has been deleted also!
I can source hosa in the perfect shape and size for that bit!
Speak to sean I guess he knows 'em inside out! And if he is running external pump/s, may have spare bits from previous set up
Can you not use braided petrol hose? or has it got 'special ends'?
Old Feb 23, 2004 | 11:20 AM
Sean Bicknell
Yeah that is exactly that Chris, I don't use any of the standard arrangement of pipes and stuff, but a lot of it especially the two car length pipes are still on the car. It's difficult to see exactly which bit you want Deano, but it looks like a little bit at the back. If that is still on the car, you are welcome to it. I am PROPERLY stripping off everything that doesn't make it either go faster, stop quicker or turn better and all of the left over bits from the standard setup will be getting the heave ho.
Give me a call and let me know if you want it.
Sean..
Old Feb 23, 2004 | 03:56 PM
Sean..
its the fuel out from the tank mate the P shaped one if that makes sense they are trying to source one but im not holding my breath but ill know more tomorrow so if they are no nearer at the garage ill give you a ring mate if thats ok and thanks for the offer and help
Old Feb 23, 2004 | 04:22 PM
Sean Bicknell
No worries, let me know. It will give me an excuse to pull the tank out anyway as that is going in the bin as well.
Sean..
Old Feb 25, 2004 | 06:17 AM
thanks for the help lads and the offer but she is back on the road and a local brake specialists made a fuel line for the garage
Old Feb 25, 2004 | 07:47 AM
cossymad's Avatar
cossymad
good going
