new clutch for my escos
Old 16-03-2008, 09:50 PM
M16NTE
M16NTE's Avatar
Default new clutch for my escos
guys my monte needs a clutch, wot would be the best 1 for it? its been stage 3 tuned.
and do you think its easy enough to do on the drive or should i put it in the garage to be done?
thanks
Old 17-03-2008, 07:46 AM
GUZZLER
GUZZLER's Avatar
AP organic would be fine (avoid 'cheap' clutch companies)
if your ok with doing gearboxes etc then it shouldn't be too much of a chore to do on the drive, remove the front prop (4 allen bolts) then its the same as a normal rwd box. Will probably need 2 of you to get the box back on, there not light!
Old 17-03-2008, 12:47 PM
krisberic
krisberic's Avatar
If it were me i would go standard again, its the weak link in the drive train and would rather the clutch give up than the box or diffs. Should handle 300bhp any way. I had a stg3 sapph on std clutch and never had any probs.
Old 17-03-2008, 03:06 PM
M16NTE
M16NTE's Avatar
ok cool, thanks!
Old 17-03-2008, 07:07 PM
ECOS95
ECOS95's Avatar
I'm going to go AP Organic when mine is due, had one on my ERST & its was a good feel & didn't slip. I'm planning on running 350BHP.
Old 17-03-2008, 07:37 PM
cossiemanden
DANISH cosworth abuser
cossiemanden's Avatar
Stage 3 is to much power on a std clutch, slips to much when launching.
can only recomend uprated pressureplate and std clutch plate, this will also slip and can take about 400 bhp/500nm (did in my car anyway) and my std gearbox took about 70 full bore launch control launches, and 25k km before 3. gear let go(clutch lasted this long also)
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
gcfcos
59
06-10-2015 05:04 PM
Quick Reply: new clutch for my escos
