how do you remove opening 1/4s
Old 06-02-2008, 03:11 PM
BIL N KEL
BIL N KEL's Avatar
Default how do you remove opening 1/4s
how do you remove the opening rear 1/4 windows? the front two screws i've done but i'm stuck as how to get the rear fixing out of the window. does the cap on the outside of the window have a screw under it?
thanks Billy
Old 06-02-2008, 03:14 PM
Kelv
Almost there!
Kelv's Avatar
if you have already removed the B pillar trim and undone the bolts on the hinge youve done the hard part.
on the rear of the window within the hinge opener there is a small roll pin. just push it out and they then remove easily.
Old 06-02-2008, 03:16 PM
BIL N KEL
BIL N KEL's Avatar
cheers mate
Old 06-02-2008, 03:46 PM
THE RADMAN
THE RADMAN's Avatar
just pop the cap off the inside of the front hinges and unscrew them then remove roll pin as above
tankybaby66
06-02-2016 02:24 PM
Orion_Gav
29-09-2015 04:50 PM
Quick Reply: how do you remove opening 1/4s
