Heater Electrics Problem.
Old Jan 29, 2008 | 04:28 PM
Cossie-Lee's Avatar
Cossie-Lee
Default Heater Electrics Problem.
Hi folks, I changed the fusebox in my coss for a nearly new one (proper high spec cosworth fusebox) but my heaters no longer work.
Im getting a live feed through the fuse but im not getting one at the switch??
When i turn the dial i cant hear the fan running but im still getting hot air through the vents when im driving but this doesnt usually happen untill im sitting at about 60-70 on the motorway Anyone any ideas???
Old Jan 30, 2008 | 01:47 PM
Dave Parker's Avatar
Dave Parker
heater seems to be the first thing to fail on these boxes had this problem on a few escorts. the wire you need is red /black and fits on the top of box at left hand side multi plug to the rotary switch check for a supply there (you wont have one)
Old Jan 31, 2008 | 08:58 AM
Cossie-Lee's Avatar
Cossie-Lee
Cheers for that mate, will have a look. Forgot to mention that before i replaced the fusebox the 3 heater speeds worked in a different order,
At speed setting 1 the heaters would run at number 2 speed, At number 2 speed the heaters would run at number 1 speed, number 3 speed was ok heaters on full blast.
Would this indicate a faulty switch perhaps? as i cant see why fitting a new fusebox would cause the heaters to stop working..
Old Jan 31, 2008 | 04:52 PM
Dave Parker
have a good look at the heater resister on the heater box under windscreen they melt and corrode
Old Jan 31, 2008 | 05:18 PM
Cossie-Lee's Avatar
Cossie-Lee
What am i looking for mate, iv no idea Is it hard to get to?? Iv had the panel off and took the switch out, is there anyway i could do a test to see if its the switch?? Im certain is isnt anything to do with the fusebox, ever since i got the car the blower speeds where a wee bit fooked
ahh, you cant beat good old ford electrics eh
Old Feb 2, 2008 | 09:37 AM
Dave Parker
heater box under bonnet has a small oblong cover size of 20 cig packet lever it off carefully and the resister is secured with two screws it has three coils and a multi plug all of which rust, melt and generally cock up. if this is damaged then your speeds will fook up. the one on my escos melted and i could smell it in the car, even the wiring had started to overheat there was a full thread on this a while a go try doing a search
Old Feb 3, 2008 | 10:55 AM
Cossie-Lee's Avatar
Cossie-Lee
Well i have now found the problem, so much for my new fusebox that was supposedly tested and in full working order Their is a dry solder on the pin that goes to the switch. Will give it a solder and see how i get on, think i might have to buy a brand new box
Old Feb 3, 2008 | 10:59 AM
THE RADMAN's Avatar
THE RADMAN
s/hand boxes arent worth the bother mate,new ones are around £250 though but it saves a lot of future problems as well,at least youve found the problem,just hope that there are no others like it
Old Feb 3, 2008 | 11:46 PM
Cossie-Lee's Avatar
Cossie-Lee
Cheers mate, my bloody horn doesnt work now Think its time to get a new box, though i might get someone to look at my old box and see if they can tidy it up, i already repaired a dry solder on it but bought a new one just to be sure, what a waste of time that was
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Flatlinedan
Sep 18, 2015 12:41 PM
